Wow that's pretty bad. I noticed the valvetrain noise a lot more but u got is def a leak. I think its at the header flange and block. My last truck starting leaking at that spot and it was almost that loud. I say pull the headers away from the block and clean all the rtv off then use OEM gaskets with a little rtv on both sides and reinstall. I bet the gas smell is from having the leak at the flange. The front o2's are probably seeing less exhaust than they should and are trying to add fuel to compensate. U may be running very rich due to this, hence the gas smell
That's just my theory for now
