SpeedJunkie
- Joined
- Sep 1, 2017
- Posts
- 183
- Reaction score
- 69
Okay upon studying my schematic more I'm thinking I needed additional diodes. Can someone look at it and tell me if it finally looks correct? Sorry for my ignorance on this, but I think I'm figuring it out. Assuming the wiring is routed properly for the relays and everything else. I may remove AUX4 from the scenario and leave the spots only powered by highbeams, as I can't think of any reason I would want just spots and not highs. The wide/cornering I'm leaving in place as they could be handy in snow/foggy conditions.
• Still looking for clarification on whether the relay with built in fuse is okay or if it needs to be in-line before the relay.
• Which diodes to use? I have both of these available and not sure the electrical advantage of one over the other.
→ AKOAK 15amp Diode Axial Schottky Blocking Diodes this would seem easier to heat shrink and place in a wire loom
→ MBR1645G- Diode Schottky 45V, 16A this is the kind that NDO used
THANK YOU ALL AGAIN FOR YOUR INPUT!!!
All I've been able to find is WPT-1279 is the Motorcraft number for the wiring harness side of the Headlight connector. I can't seem to find a part number for the connector mate. If someone does please post, this would allow you to hook these two connectors together and install in-line between factory harness and headlight assembly. Then splice your high beam and low beam trigger wires into the added "jumper" without having to splice into the factory wiring.
I originally had my fog lights wired up to the AUX1 & AUX2 switches, but I quickly realized two things:
1. The fog lights were aimed high enough that they really weren't fog lights, more like extra road lights, although I actually preferred it that way.
2. It was not ergonomic or safe to be reaching up to switch the lights on/off at the AUX switch panel.
So using the info in this thread (and linked threads) I wired up my fog lights to turn on/off with the high beams and it works amazingly well with the auto high beams. No blinding on-coming traffic and no reaching up above. I wired mine up in such a way that I can hit AUX6 and change the mode of the fog lights to operate manually using AUX1 & AUX2 as they were before. Here's a crude diagram I made on a post-it note. You will need a SPST (normally open) relay, as well as a SPDT relay. Both easily found on amazon.
I’m not sure why you’re planning on using diodes if this can be accomplished so much easier with relays. The schematic I posted earlier is exactly what you’re trying to accomplish: manual control of your fog/driving lights while also being able to switch them to an automatic mode where they turn on whenever the high beams are on. It’s working great on my truck.
I saw this harness yesterday and was trying to figure out the female end too. I believe I found it!!!
Just ordered -
WPT1321
