SpeedJunkie
- Joined
- Sep 1, 2017
- Posts
- 183
- Reaction score
- 69
I didn't tap when I made the the harness. I removed all the unused pins and soldered a lead wire to the appropriate high beam wire. I made that lead wire about 8" and connected a weatherpack connector, which then connects to a longer wire back to my relay/aux light box. so you can easily remove it if you want too. You're looking at about $50 for all the parts, but thats a small price to pay to avoid splicing factory wiring on the bestest truck around![]()
Just to be clear, I tapped the high beam wire on the harness I built with the wpt connectors, not the factory one. Then I put in a weather pack connector on the short lead coming off of the tap. So nothing factory is modified and it can be taken out easily. But the way you did it works fine too.
