Excellent. I did order that option but isn't it plastic? Didn't know it could support all that weight without the hinge points breaking
Or bring some short 4x4"s to put under the strap as a spacer.Yes there are 2 sets of tie downs on the sidewalls of the bed. One set toward the back and one toward the front and are something like roughly 8" up from the bottom.
I only strap the whole bunk with front and back tiedowns, so two straps. Never had a problem with the bunk shifting around. Just make sure you have decent ratchet straps and you'll be good to go.
The only thing is if your only carrying just a small amount of lumber, then the factory tiedown points may be too high to supply adequate downward pressure to hold the lumber to the bed. If that's the case you can easily add tie down points to the bottom of the bed for prolly less than $50 for 4.
---------- Post added at 03:08 PM ---------- Previous post was at 03:04 PM ----------
Woopdeedoo! A whole 9"!? If you are carrying plywood that can't support itself over 9" then take that garbage back.![]()
Yes this actually works I forgot about using those.
So you just strapped the top down? You didn't put a strap around the ends sticking out? Like if u accidentally hit the gas too hard, would they cascade out?
