Had some new Progressive rate Spring made
Jimbo
Mad Frog Mattis
IL
That's not really an issue. That's more of the rim protector portion. If you're going to lower the psi, I guess you could break the bead easier, but I think you'd be OK.
LekRap
Corona, CA
Thanks @Jimbo that's what I was hoping too. It's just that the guy that told me not to run them is a guy I have known for a long time and respect his opinion. I would hate to be driving 90-100 mph and worrying about a blowout. Maybe I will get another opinion from another shop though...
Jimbo
Mad Frog Mattis
IL
I was thinking chunks were taken out from the actual portion that you'd bead, not this. Others can confirm, but you should absolutely be ok. You'd get the same thing if you curbed it bad.
However, what's the date stamp on those tires?
LekRap
Corona, CA
Ugh, yeah. They are old too. They are from 2005, but they have been garaged the entire time. Still too old you think?
Jimbo
Mad Frog Mattis
IL
8 years is typically the limit. If you're going to off-road them, I'd pass and find something else. check out those grabber red labels from @INI
LekRap
Corona, CA
Thanks again Jimbo, part of me is still tempted to mount them and just cruise around the city with them. I would have a complete extra set of wheels and tires and could still use my methods on the stock at's for long drives and off road fun. I was wanting to test out the fit of 37's at my height. When my at's wear out I was wanting to get the KO2's in a 37. Think I'm crazy to mount them and just be cautious how much and wear I use them?
Jimbo
Mad Frog Mattis
IL
Nah, mount them and drive the shit out of them until they're toast. Just keep in the back of your mind that you'll be replacing them.
INI
Land, Sea, Air
for what its worth :
don't run tires that are past 7 years old. IF you are really needing projects i will find you a set.
projects are good tires but with chunks and 10 years old i would pass..
DezertRacer
Las Vegas,NV
Still looking for a single spare .. you got any in good shape? DOT or not ?
