H&m racing design long travel kit for sale
Status
Not open for further replies.
RobDietz
Virginia
It is a new unit, 0 miles on that kit
Dont have to wait for the 3 months build
-3" per side with 18" of suspensuon travel
Kit consist in
-upper a arms
- spindles
- lower a arms
- billed tie rods
- front axles
- brake lines
Suspension
- 2 2.5" dual rate coil over Kings shocks with adjuster
- 2 3.0" bypass shocks
- 2 2.5" bump stops
You will only need fenders
Parts are in panama
Is the kit +3 inches per side? Was trying to get details but the manufacture's website is no longer up.
C
canamds450
I can help you with details
It is a 3" per side Long travel suspension with 18" of travel.
Comes with
Mig welded
Upper a arm with mount
Lower a arm with gusset
Spindle
Billed tie rods
Front axle
Extended brake lines
X4 Limit straps with 2 extender
Not painted you will need to paint them
Doest not come with upper shock mount, upper shock mount cam be requested with vendor and i forgot to ask for it.
Windshield washer bottle need to be removed
Fender need to be 3" flare or glassworks 4.5" flare
Width 93" you can add a 1.5" wheel spacer at the rear.
Suspension
You can add either king or fox
This kit comes with x2 3.0 bypass shocks remote reservoir
X2 2.5" dual rate coilover shocks with adjuster knobs requested
They say it is uselees the adjuster but i like to use hi comp adjustment on my UTV and my atv. The price of the adjuster are $70
The bump stop x2 are 2.5 nitrogen empty need to be add a 100psi for that kit
The bump stop comes with a their sleave to weld them on the frame.
The metal parts upper lower and spindle are pretty heavy those are for serious stuff on the desert.
Thise are the same lower a arms used by outlaw offroad rsv1 truck
You can remain with stock wheels, the stock 34 offsetswheels.
If you order one from now it took me
Let see
May 1 of 2014
Got them aug 6
Buy it now amd you will save 3 months of waiting time
Only one box of the kimg shocks has been opened the another pair still close from the factory
Same as the raptor kit only one lower a arm upper arm and spindle has been unwraped
---------- Post added at 03:54 AM ---------- Previous post was at 03:45 AM ----------
Tomorrow i Will have details of the overseas shipping cost to miami, fl.
Shipping things from panama to miami takes arround a week
C
canamds450
$7000 metal parts
$6500 king shocks
2-3 weeks delivery.
C
canamds450
$1000 shipping cost to miami.
C
canamds450
$7000
$6500
$1000 shipping cost to miami, fl
C
canamds450
6500
6500
Can cover the shipping cost to miami, fl
C
canamds450
I'm so confused.
6500 metal parts
A arms spindles lower a arms billed tie rods front axles brake lines
Limit straps
6500
X2 3.0 bypass shocks
X2 2.5 coil over shocks
X2 bump stops
C
canamds450
FYI, that set of Kings can be had for under 4500 here in the US brand new.
Rhis kit has a special eibach coil over for the dual rate and has the adjuster, well those adjuster are 70$ each.
If you can get those suspension, You can buy raptors parts only then for $6500.
This is wat i pay for for a arms
*3.0" 3 tube remote reservoir bypass shocks $2410.15 for the pair.
*2.5" Coil overs with springs and remote reservoir, $1436.40 with custom HM coils.
*front 2.5" diam. bump stop with mounting cans $622.00
(**please note, Adjustable compression adjuster on coil over reservoir runs $1782.00 for the pair with custom HM coils.)
* Rear spacers $375.00,
* front limit straps $160.00,
* limit strap adjusters are $76.00.
*Stainless Steel Teflon lined D.O.T. approved brake lines 125.00*** custom colors available on outer protective sleeve at no extra charge. Please advise on color selection.
shipping not included in prices.
Status
