Wicked Performance Pedals
Pedals are pedals, why would anyone bother to swap them out? Because these things are Wicked!
Is it because they look cool? I think so
Is it because they provide better traction than the stock rubber ones? Maybe
Is it because the F150 wasn't born with a "Dead Pedal"? Bingo!
Maybe not important to you young whippersnappers but for me, I miss it a lot. There is a reason why high end performance cars have them. It is more comfortable, helps to adjust yourself in the saddle,
it relieves leg strain by allowing you to rest your foot in the proper position.
The product came well packed with detailed instructions, they don't however mention what tools you need, I found that a 4mm hex and a 10MM ratcheting wrench sufficed nicely. They do mention the 1/4" drill bit for the holes in the brake and gas pedals. I used a smaller bit for the pilot holes.
The dead Pedal bracket was brilliantly designed and attaches to a bolt that conveniently is sitting there waiting for you behind a removable plastic cap.
The bottom of the pedal is secured with three long self tapping screws. Don't try to power them in, it is nearly impossible to keep them from going in at the correct angle for the countersinks to line up flush. You can see the improperly lined up lower right hole...
![IMAG1131_zpsb25465ca.jpg IMAG1131_zpsb25465ca.jpg](https://www.fordraptorforum.com/data/attachments/186/186315-c3812919bd57f8ada7b6fa961343678b.jpg)
After burning/melting the carpet fibers by heating up a small screwdriver, use the small pilot hole drill bit to get it started, you can see the next two holes went in perfect, and I was able to correct the first errant hole. Be careful and use a low torque setting on these screws, easy to strip.
Like I did on my rear mat with the modification for the Tuffy, I sealed the open chambers by cleaning with alcohol and then used pure silicone. I later ended up making the opening larger so the mat would lay better. Frankly you could zip off the entire portion behind the dead pedal as it really isn't doing anything anymore.
Sometimes its the little mods that bring great satisfaction...Well Done Wicked Performance.
![IMAG1133_zps4d346e8e.jpg IMAG1133_zps4d346e8e.jpg](https://www.fordraptorforum.com/data/attachments/186/186318-ca0f93adc27585c96283982f9bc270b1.jpg)
