Chasing a really strange problem on my 2011 Raptor. 125k miles. At 112k I started getting the IWE grind, but it only made noise at low speed and during tight turns. Replaced the check valve and solenoid and it went away. Then a few hundred miles later the noise came back, but it only does it after very long drives (75 miles +). I’ll drive 75 miles let’s say, and upon slowing down off the highway and making a sharp turn into a gas station for example, I’ll get a horrific grinding noise from the front right wheel. If I turn the truck off and leave it for a while (could be 30 mins, could be an hour, really haven’t timed it), I can jump back in, crank the wheel, and no noise. It makes no noise when driving short distances and if the truck is turned off after driving long distance, it won’t make the noise. I can’t figure out what would cause this as an IWE leak would be leaking regardless of distance driven.
