In case anybody else is looking for a good price, I just ordered a set, load range C, looks like the "old" part number (speed range S):
Isn't the factory tire a load range D? And bfg didn't make a load range D in the KO2 for 35s. So it was either weaker C or stiffer E.In case anybody else is looking for a good price, I just ordered a set, load range C, looks like the "old" part number (speed range S):
Yes exactly, the last set I had was load range E (48,000 miles ago) and they are definitely stiffer, probably tougher as well and I never had a flat but figured I'd give these a try and see how they do...Isn't the factory tire a load range D? And bfg didn't make a load range D in the KO2 for 35s. So it was either weaker C or stiffer E.
Resurrecting an older thread to find out how those load range "C" tires are working out? Found a good deal on them and was wondering if they are worth the downgrade in load range.Yes exactly, the last set I had was load range E (48,000 miles ago) and they are definitely stiffer, probably tougher as well and I never had a flat but figured I'd give these a try and see how they do...
What pressure do you run them at and who installed them? Discount tire said they would not install these on my truck as the truck is rated for "D" tires.I think so!! No flats but I haven't been hitting any rocks/cactus either. It's a tradeoff between smoother ride and puncture resistance (and probably wear rate), but so far I think the C range is perfect. This is about 90/10 between asphalt and old highway/sandy beach and oilfield roads; I've only put about 5k miles on them and I think they work great, would recommend.
Are you saying the newer trucks have "C" rated tires on them from the factory? I haven't looked into this.I don't believe the GVWR of gen 1 vs gen 2 was very different, I think the C load KOs didn't exist in the proper size back in 2010-2014. I could be way way off on that. C load should work the same as it does on the newer trucks.
