Good day for an oil change.
RaptorMaryland
Maryland
Have you considered this new oil that is made for performance Vehicles?
Modern Engine Full Synthetic Motor Oil.
Link to it here, Go past the Ford F-150 getting 37 MPG and find it
here Detroit Tech Roundup: 8 Treats Including the 37-mpg F-150 Development Truck - Motor Trend
Picture http://st.motortrend.com/uploads/sites/5/2018/01/Valvoline-Full-Synthetic-Modern-Engine-5qt-Easy-Pour.jpg?interpolation=lanczos-none&fit=around|660:994
It goes after the deposits
"Carbon deposits are another big problem, both inside the combustion chamber and especially on the intake valves, which no longer get washed by port-injected fuel. Severe deposits on the piston can lead to a particularly violent low-speed pre-ignition knocking that can destroy a piston (and hence the engine). Valve deposits come from oil sneaking past valve guides and airborne oil particles in the intake manifold from positive crankcase ventilation and exhaust-gas recirculation. The Modern Engine blend contains a proprietary additive package (the only big change Valvoline representatives admitted to was replacing calcium detergent with a calcium-magnesium detergent) engineered to prevent deposit formation 30 percent more effectively than the industry standard."
Grizlbits
If sombody finds a way let me know.gen 1 filters,dead nuts on tray.
I made a deflector out of some thin sheet aluminum to divert it all into the hole. I'll take a picture if I remember to; but I basically made a prototype out of paper and then cut the aluminum sheet and bent it to fit. It didn't let any onto the skid plate.
The Germans did it right on my BMW's. Canister filter from the top of the motor. Never spilled a drop in 20 years from the filter.
