Glove box separating
smgilles
Anyone have an issue with the glove box separating from the dash?
My 2017 looked the exact same. I tore it apart and realigned everything and still had annoying gap, so I put sticky velcro along the inside that pulls it up tight when shut.
2020Raptor
South Central...NJ
On the side that is staying open, there is a rubber bumper.
I do not recall if it is on the door or the box.
Remove it and the door will close normally.
I do not know why it is there, unless for assembly or shipping purposes.
BOS1600
BOS1600
Tampa, FL
I’ll check... but this just started out of nowhere
mattrofact
Loomis, CA
Had the same issue and the glove box was removed and reinstalled properly under warranty. Also had an issue where the door card armrest leather lost its texture and that was also replaced under warranty.
Ducc
Arizona
Same issue with my '20 and glad to see dealerships are taking care of it.
ChrisK661
California
Mine came with a small gap but between the fluted item and the wall not the box door. Does it close? warranty item. That sucks
raptor ghost
West PA
^Had the same exact issue after I switched out the cabin air filter and it drove me nuts. Slightly a bit ocd so I took a couple hours to figure it out that I put it back together wrong
full
If you do not engage that one clip at the bottom most left corner of the cabin air filter cover (see 9:11 in the youtube clip). Even if you tighten down the two bolts without getting the leftmost clip engaged you'll still have a gap as pictured above. you may have to slightly flex the edges/taco them towards you and firmly push it into place until it latches
also possible the clips were broken at some point, but more likely it wasnt snapped back in place firmly enough
