Glitchy ventilated seat
bo1966
In my 2018, it seems to change over time. Sometimes, I will feel it more in the seat, sometimes more in the back, and it will migrate even during the same trip. Overall, it has gotten weaker as I've owned the truck. I don't know if it's how I'm sitting or what.
It has a filter under the seat. You may want to check it
salts001
salts001
Northern New Jersey
Update - the dealer identified and was unable to fix the issue. They had another new Raptor on display and it had the same issue as well. I didn't believe them so tested it myself. It's very strange. The dealer said they will be communicating with Ford to see if there is a resolution for this.
PitchforkR
Fwiw, I think that I remember some lines of code for this in the Forscan info sheet. It would be in the same area as steering wheel and seat temp controls. You can change the duty cycle for all the above. Maybe the fans are cutting out and restarting based on the duty cycle settings? I don’t know, but food for thought.
salts001
salts001
Northern New Jersey
That’s interesting. I will do some research on that. My next project will be messing with forscan. I just ordered the obd cable. Thanks!
DrewFish11
Vallejo, CA
Any resolution to this? My passenger seat does the exact same thing as yours. On with remote start and then turns off as soon as I hit the start button on the dash. Doesn't bother me too much but I would like to get I figured out if possible.
salts001
salts001
Northern New Jersey
Sorry for the late response, no resolution. I loaded Forscan and tried to add the heated steering wheel / vented seats to the home screen hopefully it will reset some type of glitch, didn't work so I changed it back to not having the icons on the home screen. What I also noticed is the heated steering wheel turns on when its cold no matter what setting I have it set to in the dash. I guess I didn't notice this since I bought the truck at the end of march and setting was set to auto. It's so strange.
DrewFish11
Vallejo, CA
Yeah I used forscan to put the seats and steering wheel icons on the home screen display as well. I was originally thinking the change in code possibly had an effect on the issue but from what you’re saying it doesn’t sound like it.
It’s the weirdest thing. I have the setting in the dash set to “last setting”. In this condition, only my passenger goes to full cooling when I remote start the truck. Then shuts off when I press the ignition button to officially start the truck.
Not really a huge deal for me, just doesn’t seem correct.
salts001
salts001
Northern New Jersey
My dealer is aware of this problem and submitted to corporate attaching my vin and vin of the display truck but haven't heard back (wasn't expecting to). Hopefully corporate will see others with the same issue and offer a resolution.
California
Check the connection in the unit under the passengers seat. Mine were turning on but not heating or cooling. I disconnected the plug and added some contact grease and its worked fine since.
