GEN3 Forscan
swoop1156
USA
It worked! I changed the 01D6 to 00D6 and after it wrote it changed itself to 00D5. I’m guessing that’s ok?
Awesome!! The checksum auto calculated at the end and all good!
I'm over here scratching my head why 0A didn't work when that's what my truck came with @Antho to the rescue, thank you, sir!
Antho
Not sure. 0A would typically be for a Hex to Dec value. 0A would be 10 which is the standard Dim Duty Cycle for the DRL circuit.
Thats at 736-38-01 xxxx-0Axx-xx--
hyrepower
Las Vegas, NV
I have used forscan on a few previous F150 and Raptors, I am having trouble with my 2023 Raptor as when I try to access the configuration and programming, a WARNING pops up that says “Transmission Characterization Update” then once I click OK, it wants me to enter a “Transmission Solenoid Strategy”.
It says I can access that new number that it is requesting on my transmission, however, when I crawl under my truck, I am not able to clearly see my transmission to get this number off of it, that is, if it actually exist there
