GEN3 Forscan
Antho
According to- https://docs.google.com/spreadsheets/d/1-_e09lLPPeSHoO3SsNwyqu5v3dgpbluvJcezUItTSVI/edit?usp=sharing
It looks like-
720-10-01****xxxxxx--0 =SM Cluster • TC disabled • CBEVHEVF Not China • IAKFT Intelligent Access
No idea what that does though.
Moves the setting menu from center stack to cluster.
If you currently have a 8 you change it to 0
If you currently have a C you change it to 4
Settings Menu (SM) Trail Control (TC) • China BEV/xHEV Function (CBEVHEVF) • Intelligent Access or KeyFree Text (IAKFT)
0 =SM ClusterTC disabled • CBEVHEVF Not China • IAKFT Intelligent Access
8 =SM Center StackTC disabled • CBEVHEVF Not China • IAKFT Intelligent Access
C =SM Center StackTC enabled • CBEVHEVF Not China • IAKFT Intelligent Access
4 =SM Cluster TC enabled • CBEVHEVF Not China • IAKFT Intelligent Access
Antho
If anyone has a chance, Could you post your SCCM info? Once you connect on forscan click on the car info tab. Under the configuration tab it will list the modules and the calibration/strategy info. Thanks for any help!
Antho
Added a Few more items.
DRL INCLUDE FOGS
726-39-01 02xx xxxx xxxx
FOGS STAY ON WITH HIGH BEAMS
726-39-02 xxxx0 xxxx xxxx
DRL INCLUDES PARK LAMPS
726-38-01 xxxx xxxx 01xx
DOUBLE HONK DISABLE
726-63-02 xxx0 xxxx xxxx
LANE CHANGE BLINK NUMBER WITH DEFAULT 8C
724-01-01 xxxx **xx xxxx
80=NULL, 84=1, 88=2, 8C=3, 90=4, 94=5, 98=6, 9C=7, A0=8, A4=9, A8=10
LANE CHANGE BLINK NUMBER WITH DEFAULT 0C
00=NULL, 04=1, 08=2, 0C=3, 10=4, 14=5, 18=6, 1C=7, 20=8, 24=9, 28=10
OFF-ROAD IOD
7D0-01-03 xxxx xxxx 2xxxx
OFF-ROAD IOD #2
7D0-01-04 xxx6-xxxx-xxxx
**MY FACTORY WAS 4**
ADD OIL TEMP TO MEASUREMENTS PAGE
720-06-01 xxxF-xxxx-xx
SETTINGS MENU IN CLUSTER
720-10-01 xxx4-xxxx-xx
MY FACTORY SETTING WAY C. VERIFY YOURS BEFORE CHANGING
PandaBoi
Dallas, Texas
@Antho thanks for going through and testing codes to see what works for the Gen3! I’m picking mine up next Saturday and saved a lot of this info. I was going to do the same thing as I figured that the gen3 will have some settings different than the regular f150s.
Do we know if the gen3 can do the auto fold mirrors when locked? I think it’s called Lincoln style or that might be one of the options for it.
Staff online
96,484
60,439
bob barton
