GEN3 Forscan
Stan G
USA
Thanks for reposting @Antho. I haven’t had any flickering issues with brightness setting & I stared long and hard at those damn things...daytime and night. Will triple check though. Thanks again bro!
Which item is the brightness setting? maybe I'm missing that one.
shookj95
Raleigh NC
I need a reminder... Should we be using the as built module or the normal one...I am getting an error when trying to enable Bambi mode.
When I hit "write" I get - Incorrect checksum of data entered....I hit continue anyway and I get service procedure has been interrupted
Littlefx4
See post #9; it’s the “full brightness setting”. Some members reported the Amber DRLs were flickering so they reverted back to original setting.
Stan G
USA
I liked it and glanced right over it thanks!
RaptorCDH
ganooch
Dallas, TX
From what I understand the "easy method" accomplishes the same thing but will have much less options available as those have to be setup in the Forscan software updates. The "hard way" gives you access to every configuration line and let's you change or mess anything up you want.
Yup, the easy way makes the same change as doing it the "hard" way, but with a neat GUI selection rather than replacing numbers.
Ryed
Warren, VT
Has anyone had any luck using Forescan on a MacBook? I could install a Windows parallel on my MacBook Pro, but would avoid doing that step if I can work directly off my Mac. I won't have my Raptor until sometime next year (build date moved from 12/6/21 to 1/24/22), but I could make some changes and get familiar with Forescan on my 2019 SuperDuty.
Littlefx4
That should give you plenty time to get a Windows PC.
Stan G
USA
Do yourself a favor and install a vm of windows. It doesn't work on Mac
