GEN3 Forscan
Antho
Thanks for reposting Antho! I was hoping to tweak things and post in that original thread. Thanks for bringing back our sanity! haha :favorites37:
I was going to make a new thread but been slammed at work and didnt see any post about the thread missing until today.
JCO
Denver
You guys know if you can enable the TrackApps on the Raptor? I see the options in Forscan and on the 2021 F150 Sheet (720-06-01) but nothing seems to happen with the changes. Maybe there's a module I'm missing?
Littlefx4
I had the admin remove the thread because i didnt want others using the brightness setting if it is causing undesired effects. I was unable to edit the original post so i had to delete it. No ford conspiracies.
DRL INCLUDE FOGS
726-39-01 02xx xxxx xxxx
FOGS STAY ON WITH HIGH BEAMS
726-39-02 xxxx0 xxxx xxxx
DRL INCLUDES PARK LAMPS
726-38-01 xxxx xxxx 01xx
DOUBLE HONK DISABLE
726-63-02 ***0 xxxx xxxx
LANE CHANGE BLINK NUMBER WITH DEFAULT 8C
724-01-01 xxxx **xx xxxx
80=NULL, 84=1, 88=2, 8C=3, 90=4, 94=5, 98=6, 9C=7, A0=8, A4=9, A8=10
LANE CHANGE BLINK NUMBER WITH DEFAULT 0C
00=NULL, 04=1, 08=2, 0C=3, 10=4, 14=5, 18=6, 1C=7, 20=8, 24=9, 28=10
OFF-ROAD IOD
7D0-01-03 xxxx xxxx 2***
Thanks for reposting @Antho. I haven’t had any flickering issues with brightness setting & I stared long and hard at those damn things...daytime and night. Will triple check though. Thanks again bro!
ganooch
Dallas, TX
Same here, no flickering for me. Seems some have it, some don't. It is strange though.
RaptorCDH
DRL INCLUDE FOGS
DOUBLE HONK DISABLE
OFF-ROAD IOD
Hi —Can you post the original pics that accompanied each Change/program —showing what each line of code did for the lights was very useful…Many Thanks!!
RaptorCDH
Hey Everybody—
I am trying to educate myself about FORSCAN…I have seen the posting here using the spreadsheet method—-ie. entering some code changes by line….I am sure everyone has also seen the way to make changes using the OBDLink EX without entering spreadsheet codes…called “FORSCAN the easy way - No spreadsheet required” on several YouTube postings…it seems easier to me and mostly eliminates the possibility of input errors by user making the changes…
Is there a drawback to using this method? I don’t want easy if its not right and leads to other issues….
Cheers!!!
jjslat
jjslat
Georgia
Hey Everybody—
Cheers!!!
From what I understand the "easy method" accomplishes the same thing but will have much less options available as those have to be setup in the Forscan software updates. The "hard way" gives you access to every configuration line and let's you change or mess anything up you want.
