GEN3 Forscan
10SpdsOfFury
Jacksonville FL
what is the lincoln style mirror mod? ive seen it in forscan when messing aroudn with other items. Also are you serious about being able to turn on massage seats? figured that wouldnt have been included in our seats
It just folds the mirrors when you lock the door and unfolds the mirrors. When you unlock the door, I’m not sure but I believe all the GEN threes have that option in the vehicle settings.
MDJAK
NY
Yes the gen3 has auto fold and open but there is a difference. Not exactly sure what that is but someone here posted previously the difference
tm965
NOVA
thats what i figured/we already have it enabled when we receive the trucks
Littlefx4
Anti-Glare no longer needs forscan. It was enabled in one of the latest software updates.
Regarding OTA updates, I’ve only received two Ford Power-up updates. Mind posting the update you speak of? Should be visible in your Ford Pass app.
Chuckaroo91
Boise, ID
Hey @Antho, I'm going to be changing to 37s. Could you give me a brief overview? I know it's been asked a bunch, but I would like to get it right the first time. Once I have it done, I'll make a write up in the suspension forum and get it stickied. - I know I need to change some lines in the BCM, but I'm a little confused on what to change them to based on the circumference of the tire. - Then, I need to do a PCM/TCM relearn. Do you have a quick explanation or directions on this one? - Lastly, I'll do the ride height calibration using the pinned procedure in the Gen2 suspension forum. Thanks in advance.
You can check some of my post and replies on this thread. I did it a few weeks ago and had some questions on it. See #310 and #311.
I tried doing it by changing tire circumference and it threw a bunch of codes afterwards. Would do it the way noted in the posts above - did it that way and have had no issues. Speedo is spot on to multiple GPS speeds.
j1nino
Long Island
Has anyone been able to use Forscan to remove the "Full View Not Available" message on the Tailgate camera view when driving?
oddworld
Anyone know what DTC P160A is and how to permanently clear it? Keeps coming back after I clear and restart. Think it’s related to the speedo recalibration.
I’ve done:
75% DRLs
DRL includes parking lamps
Adjusted my speedo for the factory 37s
Disable Double Honk
What did you mean by "adjusting your speedo for the 37"?
Are you referring to the shock calibration that was highlighted in Post #210 (linked here) https://www.fordraptorforum.com/threads/gen3-forscan.87665/post-1788852
If I bought a 37, and haven't changed the tired or shocks, then anything that I need to do here?
