GEN3 Forscan
Littlefx4
Need some help with "fog lights on with DRL". I changed my As Built to the numbers below but i cannot get the fog lights to shut off with my DRLs. The Fog Light icon in the dash will turn on and off when i hit the button but the fog lights themselves will not shut off when DRLs are activated. I have Parking lights turned on with DRL and all that works fine.... any help is appreciated!!
DRLs - allow fog lightsBCM726-38-0201xxxxxxxx--allows fogs to be turned on with DRLs
I made the same changes in forscan and my fog lights do not turn on with DRL's. Hope someone has some input on this.
You may want to double check that you gents are changing the correct code & reattack. I’m not seeing 726-38-02 in the pic below. From the pic, it appears you‘re trying to make the first change as that code is 726-39-01….
vgzprt
NJ
Thank you very much for posting this. I will try it when I get out from work. When I changed the 726-38-02 01xx-xxxx-xx-- it shut off my 3 marker lights so I restored it back to as built 00xx-xxxx-xx-- and all is good again.
The spreadsheet has different #
kpecks
Florida
It looks like the google sheet spreadsheet from the f150 forum is not accurate and the proper line code is 726-39-01....
Tusk
Springfield, Missouri
I'm going to change my DRLs to 75% from 100%. I'm getting some flickering.
It looks like I changed 726-42-01 to 0202-xxxx-xxxx. Does it need to stay like that and then change 726-38-01 to xxxx-4Bxx-xxxx?
Also, on the Glare Free, do you make all of the changes at once or make the first then reset?
Littlefx4
Regarding your DRLs, I would reset them to the factory setting and then change the appropriate code for 75% duty cycle…726-38-01 to xxxx-4Bxx-xxxx.
As for the Glare Free, it doesn’t matter the order in which you change the codes…just be sure to reset the APIM after changing those codes. I caution you to double check & triple check that you’re changing the correct code.
Tusk
Does anybody know the default setting for 726-42-01?
Littlefx4
Wait, wut! You didn’t back up your modules prior to changing it? Bad move. Always save your modules first that way YOU know what the original settings are should the need arise to revert back to factory settings.
default: 726-42-01 0303 0404 0583
Tusk
Thanks!
I backed them up. I changed several things so I was just going to change the brightness back to stock then adjust to 75%. I guess I should just load the original file.
Chuckaroo91
Boise, ID
@mkraus01
Only have to make the below changes. The 726-15-01 is the same as the 1st 2 digits of the tires circumference are the same. Just the last 2 digits. 35" (0A5D) and 37" 0AC1)
37" = 726-15-02 C1xx-xx
35" = 726-15-02 5Dxx-xx
I may need an explain like I'm 5 here. Attached is what I am seeing on my 35" Raptor. How would the first line be adjusted? 726-15-01?
