Gen2 Front Suspension On Gen1
HalfRap
hi zombiekiller
I think you had to do this manipulation, is it possible to take the knuckle of gen 1 and install on gen2 and only in front shock or /and rear, then for the arms, it is necessary to take only the high camburg or the set.
i was interested if you have picture for the installation.
I would think so If you want to Bore the hole in the Gen1 Lower Knuckle to a gen2 LCA ball joint spec .. Gen2 LCAs have a little larger in Diameter Ball joint shaft that goes through the knuckle.
