Gen 1 suspension overhaul
C
Cody Templeton
Des Moines, IA
Are there any front coilovers that don't make a bunch of noise or ride rough on road? Would it be worth going to Gen 2 shocks in the front maybe?
btkeenan
Monrovia, CA
Big fan of the king 3.0s I got all the way around to replace the factory fox’s. Plush on the road and only makes slight noise when hitting larger potholes/dips. Also has the dials on the reservoirs that you can make them firmer or softer depending on conditions.
C
Cody Templeton
Des Moines, IA
No issues with bypass noise while driving on the road?
btkeenan
Monrovia, CA
Not yet in normal everyday driving. First time hearing the bypass noise I thought something was wrong. Called the shop that installed them and verified that it was normal. Any of the small stuff on the road like the lane dividers or imperfections in the road it does a good job absorbing and making little to no noise. I only hear the bypass on large potholes/bumps or when I don't slow for speed bumps. If it was clicking/squeaking constantly I would have dumped them online and likely either gone back to a new set of the OEM fox shocks or something else. Can't stand erroneous noises in the cabin.
Gorzz
Canada
IF you got the cash kickin, just go with the Icon Stage 4... I dig it. In the fine tuning stage now but I absolutely dig it. Added the SVC bumpers and tie-rods and waiting for the Lee Steering pump to come in. Send it!
TomDirt
Hesperia CA
"Suspension is currently stock minus top perch, a small lift block in the rear,"
There's already one of those from the factory.
C
Cody Templeton
Des Moines, IA
Sorry, a slightly taller block than the stock one. That's not my concern at this point though because I plan to change leaf springs and potentially block back there anyways.
C
Cody Templeton
Des Moines, IA
Since the truck will be in storage here shortly, the big project for this winter I think is going to be getting all this stuff figured out so I can install it in the spring.
96,789
60,752
jubes
