I am sure this will be an easy one
Tried searching a little, but wasn't sure.
And I am sure that once I get to it, it will be obvious.
Can the top nuts be removed from the front shocks on a Gen 1 (2011 Super Crew) and drop them out of the springs??
Getting closer to either replacing or getting all 4 shocks.
See most threads and videos show removing the whole assembly, spring compressor, removing retaining ring, etc.
Looking at the shock itself, wondered if the lower mounting bolt can be taken out, lower control arm dropped down, top nut taken off shock, and shock slid out center of spring.
Thought it would be nice if that is the case.
Disturb a lot less stuff at the top mount.
And of course...next...
Can new/rebuilt shock have ring placed on body (planing mid point instead of lowest-read that is OK on 2011-want a lil' bit higher/level front end), bolt in lower shock mount, drop truck weight back on, and reinstall top mount bolt???
OK, and one more last one
Going from lowest ring position to mid, will require front end alignment, correct?
Guessing a softball for everyone who has already been there, done that.
THANKS in advance ! ! !
