Gen 2 towing a 7k lb travel trailer
mmayo
how is the ride on the deaver +3HD when bed is empty? I have the retrax pro bed cover which I believe weighs just under 100lbs.
OPT PRIME
Same as stock. Definitely more planted, less hoppy.
mmayo
Thanks for the responses....seems the HD Deavers are the way to go, not sure why you'd go w/ regular unless you were never going to put anything in the bed or tow......
Loufish
Burbank CA
Did anyone change to sport mode when towing to extend the distance between shifts?
Mine shifts pretty hard in Sport, which I like, but when towing a fast shift is better. Tow mode also often changes the torque converter lock up logic to keep the trans cooler along with changing downshift points as well...
Yeah try it to see how it works, but I'd use Tow when towing for sure...
swanstreaming
Use the “tow” setting. It will keep it in lower gears when descending, too (if you apply break).
OPT PRIME
First medium distance tow with Deaver +3HD and SVC bumps. I did NOT lower the bumps in Preparation to tow, yet they worked wonderfully.
signalbobby
at full compression, are those ubolts slamming into the frame? can't tell if itll clear.
