Gen 2 towing a 7k lb travel trailer
FordTechOne
Detroit
To bring this thread back to life. I have a 19 Screw and am looking at TT in the 21-25ft range with a dry weight of 4100-5000 lbs. the tongue weight on all these different trailers is all over the place. Will definitely get a WDH, am thinking Anderson. So unless I load up the bed, I think I should be ok. I may have to put a 3000+ amp service for the a/c (likely 15,000 btu).
Will I likely be ok on stock shocks and wdh alone?
am new to this so am looking for some guidance.
Dana
I towed 6K with my 2019 (U-Haul car trailer and 2004 Mustang Cobra), no WD hitch. It towed perfectly except for the squat; the suspension is what really limits these trucks for towing. With a WD hitch you should be fine. Factory tow rating is 8,000lbs; as long as you're below that number and your tongue weight is in spec, you should be fine.
