Gen 2 Torque Specs?
Antho
Anyone have a sheet with the torque specs? I've seen some sheets for the Gen 1 with the common parts we swap or replace listed with torque specs. Anyone got one handy? I'm currently looking for specs on rear shock upper and lower nuts and front lower CA nuts/bolts. If not, I'll buy the service manual and post up. Just wanted to check here 1st. Thanks!
Loufish
Burbank CA
I know this....bottom front shock mount bolt spec is 430 lb/ft.....and a lot of guys tighten them up after some type of work and don't get them tight enough and wind up with a front "clunk"...
I'll keep an eye out for some more info and of course share what I find..
Antho
Antho
Thanks Lou! I’m keeping my eye out but my just buy the service manual over the weekend.
sixshooter_45
Arnold
This is the information I copied from another post.
Torque Specifications:
.....................................................................NM...lb-ft......lb-in
Shock absorber nuts..........................................90....66........N/A
Shock absorber shield bolts (Fox shock guard)........4.....N/A.........35
Spring shackle-to-frame nut ..............................185..136.......N/A
Spring-to-frame nut .........................................350..258.......N/A
Spring-to-shackle nut ......................................185..136.......N/A
Spring U-bolt nuts a .........................................torque to yield
Jounce bumper-to-frame bolt..............................35...26.........N/A
Front Suspension
Brake caliper anchor plate bolts...........................250...184........N/A.Loctite
Brake disc shield bolts........................................17.....N/A.......150
Brake hose bracket bolt......................................30.....22.........N/A
Halfshaft nut....................................................27.....20.........N/A
Integrated Wheel End (IWE) bolts........................15.....N/A........133
Lower arm forward and rearward nuts...................350....258.......N/A
Lower ball joint nut...........................................150....111.......N/A
Shock absorber lower nut...................................550....406.......N/A
Shock absorber upper mount nuts........................40......30........N/A
Shock rod nut..................................................55......41........N/A
Skid plate bolts................................................48......35........N/A
Stabilizer bar bracket nuts.................................55......41........N/A
Stabilizer bar link nuts.......................................80......59........N/A
Tie-rod end nut...............................................115.....85........N/A
Upper arm-to-frame nuts..................................150.....111.......N/A
Upper ball joint nut..........................................115.....85.........N/A
Wheel bearing and wheel hub bolts.....................175.....129.......N/A
Wheel speed sensor bolt...................................18.......N/A..... 159
Wheel speed sensor harness bracket bolt.............12.......N/A......106
Rear Brakes
Axle vent valve.................................................18.....N/A......159
Brake caliper bleeder screw.................................20.....N/A......177
Brake caliper flow bolt........................................40......30.......N/A
Brake caliper guide pin bolt.................................30.......22.......N/A
Brake caliper support bracket bolts......................165.....122......N/A.Loctite
Brake flexible hose bracket-to-axle bolt................30.......22.......N/A
Brake flexible hose bracket-to-frame bolt..............17.......N/A.....150
Brake noise damper...........................................14.......N/A.....124
Brake tube fitting..............................................17.......N/A.....150
Front Brakes
Brake caliper anchor plate bolts...........................250...184......N/A
Brake caliper flow bolt.......................................40......30.......N/A
Brake caliper guide pin bolt.................................37......27......N/A
Brake disc shield bolts.......................................18......N/A.....159
Brake flexible hose bracket-to-frame bolt..............17......N/A.....150
Brake flexible hose bracket-to-wheel knuckle bolt...30......22.......N/A
Brake tube fitting.............................................17......N/A......150
Driveshafts
Driveshaft flange bolts .......................................103...76........N/A...loctite
Front flange-to-pinion flange bolts.......................55.....41........N/A...loctite
Bumpers
Frame mounting bracket-to-front bumper nuts.......115....85........N/A
Front bumper cover-to-fender bolts......................3......N/A........27
Front bumper cover-to-radiator support bolts.........3......N/A........27
Rear bumper nuts.............................................175....129.......N/A
Rear harness ground bolt....................................10.....N/A.......89
Tow hook bolts.................................................115....85........N/A
Lug nuts
Start by hand, tighten in star pattern to...............204...150......N/A
Bed bolts
Bed box to frame...............................................80....59.........N/A
(suggested to discard and replace these bolts)
Spark plugs
5.4 and 6.2......................................................12....N/A.......106
5.4 *8 plugs, 6.2 *16 plugs
Drain plugs
Oil drain plug both 5.4 and 6.2..............................23....17........N/A
Capacity, both 5.4 and 6.2, 5w20, 7 quarts with filter R&R.
Oil filter part#FL-820S
Front diff fill plug................................................25....18........N/A Capacity, premium 80w-90 gear lube, 1.70L/3.6pt
Rear diff fill plug..................................................30....22........N/A
Capacity, Synthetic 75w-140, 2.84L/6.0 pt
Transfer case
Drain plug..........................................................15....N/A......133
Fill Plug..............................................................15...N/A......133
Capacity Motorcraft Transfer Case Fluid
XL-12 (fancy name for ATF fluid), 1.4L/2.9 pt
Transmission dipstick fluid check procedure is a PITA and better left for another thread.
To drain the oil on the diffs, the cover needs to come off.
Differential cover
Rear differential housing cover bolts......................45.....33.......N/A
Front differential housing cover bolts.....................32.....24.......N/A
Fuel Tank
Fuel pump module cover nuts.............................. 9.....N/A........80
Fuel tank skid plate nuts.................................... 20....N/A.......177
Fuel tank support strap bolts.............................. 47.....35.........N/A
Power Steering System
Inner tie rods...................................................120.....89.......N/A
Oil drip shield bolts..............................................7......N/A......62
Outer tie-rod end nuts........................................115.....85......N/A
Power steering fluid reservoir stud bolt....................8.......N/A......71
Power steering pump bolts and stud bolt.................25.......18......N/A
Pressure line bracket-to-crossmember bolt...............7.......N/A.....62
Pressure line bracket-to-engine nut........................40.......30.....N/A
Pressure line-to-pump fitting.................................75.......55......N/A
Steering column shaft-to-steering gear bolt............30.......22......N/A
Steering gear nuts and bolts.................................440.....325.....N/A
Steering gear turn tubes clamp plate bolt.................11......N/A......97
Steering line clamp plate bolt.................................23.......17......N/A
Tie-rod jam nuts.................................................103......76......N/A
Turn tube banjo bolt dampers.................................43.......32.....N/A
dsiggi
Front Suspension
Rear Brakes
Front Brakes
Driveshafts
Bumpers
Lug nuts
Bed bolts
Spark plugs
Drain plugs
Transfer case
Differential cover
Fuel Tank
I too was looking for a gen 2 list.
These come from a Gen 1 list but I think they are similar in a lot of cases
