I want to say there are 16 of them on 6.2. Someone please correct me if I’m wrong.True. $90 x 8 = $720![]()
16 plugs, but only 8 coil packs. Each coil pack serves 2 plugs, one upper and one lower. It sits on the upper plug, then a spark plug wire comes off the top and goes down to lower plug.I want to say there are 16 of them on 6.2. Someone please correct me if I’m wrong.
Yep, my son just corrected me16 plugs, but only 8 coil packs. Each coil pack serves 2 plugs, one upper and one lower. It sits on the upper plug, then a spark plug wire comes off the top and goes down to lower plug.
This is true to a point. if you let the coil arc to long it has ribs that hold the resistor pill. the ribs are easily destroyed by the arc. they are pot metal. once the ribs that hold the pill in place is destroyed. The coil Its self is still good but the rest is junk and can not be fixed. you will need a new coil. Ask me how I know....LOLMyth buster time, the coil packs do not need to be changed on any sort of schedule. If you disagree with what I just said tell me where in the ford shop manual or any other manual this is stated. Do coils go bad? Yes on occasion and when they go bad it needs to be replaced but they are like the many other electrical components on the truck. Replacing the coils is a feel good practice that is for the most part a waist of money. Coil packs are pretty robust and usually the the component that connects to the coil is what goes bad such as spring and resistor, plug wire or spark plug. I wish people were more informed on this subject.
