Pete_n_SoCal
Hi everyone. My daughter bought herself a 2011 Raptor back in 2019.
Three years later it's been a great truck with zero problems.
She added the shell, Rigid 360s in the front bumper, leveled out the front and then installed the 35" tires with Method wheels.
The truck has been in its current configuration for at least 2 years.
The other day while driving home from work she called me and said the truck was running weird and the battery light was on. I didn't think much of it. I assumed the alternator was not charging the battery, and the battery finally died. I was going to give her a hard time for not watching her gauges, but then discovered there is no volt gauge on the dash. I'm old enough to remember when cars only had idiot lights. When the light comes on it's too late to fix the problem. With all of the other fancy things these trucks have they can't have a volt gauge?
Anyways, turns out the alternator was bad. Swapped out the alternator and charged the battery. Once the battery was charged, I started the truck, put a volt meter on the battery terminals and verified the output was good. The next day she hopped in to head to work and the battery was dead. I thought maybe the battery was now bad from being discharged as low as it was from her trying to get home. Took the battery to an electrical shop so they could charge it and perform a load test. Battery checks out fine.
Installed the battery back in the truck. Installed the positive cable first. When I went to install the negative cable I noticed the spark when the terminal was making contact with the battery was very white and I could actually hear it. Swapping the leads around on my volt meter I'm able to see that there is indeed a drain, but when the volt meter makes contact with the battery and negative cable the parking lights come on. So of course the volt meter will indicate a possible drain.
I've been wrenching on vehicles for a long time, but this truck is way newer than anything I'm used to. I've read some other threads about the truck needing to be "asleep" before trying to get a reading from the volt meter about a possible drain. It seems like I'm waking up the truck whenever the volt mater makes contact. How do I put the truck to sleep so I can diagnose things?
I did start pulling fuses and relays from the under hood fuse box, but each time I go to attach the negative cable the bright white loud spark appears. These trucks have lots of fuses between the box under the hood and on the passenger side kick panel. Hopefully there is a better way to figure things out.
Any help would be greatly appreciated. Thank You
