Battery draining overnight 2022
Brad_hartpro
Springfield MO
2022 with pano, 2k power, recaros. Battery is draining when parked for extended period of time (8hrs+). Had factory 2yr old battery tested and alternator as well, both good. Thought maybe I wasn’t driving enough to fully charge it so I put a battery tender on it overnight. Problem cured for 2 days then battery dead (11.53 volts) again. Replaced battery with Oddysey with same CCA rating. Drained over a volt overnight. Any insight as to what may be drawing power?
Ruger
Northern Nevada
You likely have a short. I had one a couple of years ago, and tracked the problem to dust contamination in the electrical socket on the trailer hitch. A blast of compressed air solved the problem, and now I check that every so often. If you have electrical accessories installed as most of us do, do a thorough inspection of the wiring.
Brad_hartpro
Brad_hartpro
Springfield MO
I have a Uniden R8 radar detector and Cobb tuner plugged in and that is it. I plan on unplugging one each night over the weekend to see if it’s either.
Waaptuh
Apple Valley
I had something similar happen to me on another car and it turned out to be the security system. I guess it wouldn’t turn off so it would drain the battery. Took the dealer 4 separate visits to figure it out
Swacer_2
PA
My 22 37PP will literally drain 1/2 the battery in 12 hours or less...if....the key is within 20ft of it. I have to store my key across the house up 2 floors in order to keep it far enough away to avoid battery drain.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
Dealing with this everyday right now. Might just buy one and throw it in. Ford won't replace it. They say it tests good.
Gator85
York, PA
Have you tried putting the fob in a Faraday bag when not driving the truck?
