Geiser vs Eibach vs Collar
Leftsidej
Leftsidej
Missouri
Eibachs are produced at a massive quantity in a huge warehouse. Geisers only make several a batch.
SCMike
San Clemente
I purchased a set of eibach to level my 2019 raptor. I’m getting them installed this week along with a set of 17” venomrex 602s. I’m debating between 35x12.5 or 37x12.5 ridge grapplers. I love the way the 37s look, and wanted to know if anyone is running a similar set up with good results. I don’t mind trimming the liners, but that’s the extent of the work I want to do to fit them. For now I’ll be on the stock rear suspension, but will likely upgrade to deavers in the spring.
I will be doing mild off roading (no jumping)
LeboRaptor
Nyc
Post some pictures after. I want to do exactly the same thing with the same tires.
SCMike
San Clemente
not sure I’m going to do 37s or not. At this point, I’ll probably go 35s unless someone can chime in here with a sucess story running 37s on Eibach.
Leftsidej
Leftsidej
Missouri
I've wanted to go to 37s as well. Believe with Eibachs you still need some minor trimming, which is scary.
Gdog
Colorado
I'm sorry but I would have a hard time whacking the shit out of my wheels wells on a brand new raptor just to fit some bigger tires in there. Just my opinion
SCMike
San Clemente
yeah, not looking to whack the shit out of my wheel wells. I don’t mind trimming a small amount of plastic off the lower corner, but that’s really as far as I want to go.
I’m getting the tires installed tomorrow and have not heard from anyone with my set up on 37s so I’m just going to do 35s at this point.
Leftsidej
Leftsidej
Missouri
Ask the shop how much trimming would be required to stuff 37s. I don’t think it would be much with eibachs.
SCMike
San Clemente
So I had the tire shop test for a 37 on the front and it was only going to rub on the inner fender liner. A little trimming would have been all that was needed. With that, I still ended up going with 35s. The only reason is because I wanted to be able to use my factory spare tire location and the 37 would not fit. The 37s looked really good, but I chose practicality over looks this time around.
SCMike
San Clemente
