Geiser vs Eibach vs Collar
Woolaroc
Oklahoma
I saw it mentioned earlier in the thread, but didn't see an answer. The Geisers are a progressive spring like the OEM ones, but the Eibach's are linear. How does this change the ride, and what does it actually mean in the grand scheme of things. I was leaning towards Geiser but it seems that also requires rear-leaf spring replacement to make it level.
Quaesta
Linear springs, have a spring rate that is consistent along the entire length of the spring as it is compressed. Progressive springs on the other hand, have a spring rate that increases or changes with the compression of the spring.
Progressive springs will ride better than Linear springs.
rjlljr
Florida
Should be the same for 2020’s too.
I only ask because Eibachs site has both 1.7 abs 2.5 springs available for the 2020.
I don't want to mess up and not lift the font enough.
Anyone have any first hand experience with both sets?
I want the front level or a touch higher than the back. At this point I'm not looking to lift the back.
Phil O
Sacramento, Ca
Where on their site? I only see the 2019/2020 as a 1.7” lift... my 3019 with the 1.7” sits pretty level.
K223
Florida
Im nearly 100% sure, the 2019 and 2020’s are identical configurations from Ford. 2017-2018’s would get 2.5” height from the Eibach springs.
I have only seen one spring listed on there site for these trucks. Did they add another? Here is the part # for the 1.7” height for the 19’s and 20’s.
View media item 14626
