TXRaptor
- Joined
- Sep 15, 2010
- Posts
- 1,851
- Reaction score
- 1,049
With the above setup up Geiser/ Deaver +3 would 37/12.5R20 fit?? Wheel 20x10 -18mm offset?
Thanks
No. As I mentioned in another thread, a 10" wheel with a -18 offset will stick out a *lot* further than factory which are pretty close to even with the outside edge of the body.
Factory wheels are 8.5" wide with a +34mm offset
Fuel wheels you are asking about are 10" wide with a -18 offset
Wheel Offset Calculator:
https://www.1010tires.com/Tools/Wheel-Offset-Calculator#
The difference will be 71mm or 2.8 inches for the outer position! Yikes!
As others have said, if you plan to only drive the truck on the street and never go fast over bumps, you "might" be fine. You are much better off using those wheels and tires on a 6-8" lifted F150. Otherwise, you will need to buy +3 fenders and bedsides to clear the 37" tires under compression for your Raptor. (assuming you have one...)
https://fiberwerx.com/products/pf/ford/
As a final note, my Fuel Trophy wheel are 17x8.5" wide with a +6mm offset. They work with the above suspension specs with only minor trimming.
