Now that the truck is at Outlaw the race prep has begun..
The first order of business was to get the bed off and get the interior out.
They also got the front end apart so the it can be freshened up and the new trick Icon's coil overs can be installed..
The rear of the frame was stripped of the factory shock mounts and other none need items.. They also trimmed the exhaust back. This will be rerouted later..
While this was going on a second crew was working on the inside..
The center console will be removed for the race.. This is to help with ingress and egress of the 3rd seat passenger (Patty).
This means some brackets had to be made to keep the shiftier in position and the the up-fitter switch panel...
Also the dash was partaly taken apart so the second GPS for the co-driver (wiz) can be installed..
Mean while at the back of the truck work is progressing with the renforcement and the the VERY trick new Icon bumps and modified bump cans
They used a set up spring to find proper placement of the upper shock mount and work the timing out for the bumps..
With the timing worked out for the bumps and the proper shock mount location found things are starting to get buttoned up in the back....New +3 Deevers are now in..
Got love the spider web frame enforcement
Stay tuned for more....
And as always please feel free to ask any questions..
We would also like to take a moment and again thank Connor and his crew at Outlaw for the hard work and the dedication they have put into getting this project done.. Just stand up guy's.......
