Thanks Geoff for the awesome thread! I recently pulled the trigger on the ATI balancer mentioned earlier in the thread and figured I would try to add some value here. Attached are a few photos; one of the finished install and I also attached the part numbers for the belts that are required to run it. The ATI balancer is 4% overdriven from stock so I had to play with a few different belt sizes. I also discovered that if your Gen 2 3.5 has 112,000 miles like mine, the overdriven pulley makes the old accessories less than happy. I ended up replacing the water pump, decoupler pulley, idler pulley and tensioner with new Motorcraft parts. Also, another side note; on the Gen 2 stuff the crank isn’t keyed but the ATI balancer is. I was instructed by ATI to just throw a small dab of RTV in the empty keyway to prevent an oil leak. I hope this helps some of you guys looking to do the swap!
Also for Geoff,
After install I noticed a more pronounced hollow sounding knock coming from the engine at low RPM. Only happens in drive and only on very low speed light throttle. Part of me wants to says it is direct injection noise. With your experience with this balancer, did you notice anything like this? Also, any idea if ARP makes a crank bolt that will fit this engine? Is it the same size as the coyote bolt?
Thanks guys!
