Fuel Reserve
Carson
Oklahoma
I refill mine anywhere I'm travelling that the gas is cheaper than I have in my home town. Also, mine rarely says less than 200 miles to E. It's comforting to know I could go 450 miles at a time if I need to for some reason. It also keeps the cost per fillup down to $60 or so if I top it off more frequently.
I've never let a vehicle I was driving get to less than 50 miles to E; just not in my nature to do so. Not many of the gas stations within 50 miles have credit card service at the pump and none of the gas stations locally are 24 hour so an intelligent person keeps at least half a tank of gas just in case they have to make a trip unexpectedly.
Aaron
Meme Corps Commandant
WA
I live one block from a 24 hour gas station, so it's never really a big worry for me.
I let mine get down to "20 miles' today and filled it up. She took 24.8 gallons, considering I have a 26 gallon tank, I'd say 20 is pretty accurate figuring i've been averaging about 14.6mpg
Reptar
Jersey
It all varies. The truck mpg calculator isn't 100% accurate. And it's also not a blanket "x.x mpg" off every time either. It all depends on your driving habits. The computer can trend pretty close over time, but if you do a couple WOT bursts, or a couple heavy load trips on 1 tank, but the rest of the drive is as you always do, the mpg calculator may show almost the identical thing, but it can be off just enough that you could run out at 0 to E, 5 to E, or have 0 to E on there for 5 more miles.
I've only hit 0 to E twice on my screw. Once was the first tank, I figured everything was brand new, no contaminants in the tank yet, so if I was going to see if it could go to E to test it up front so I knew incase of emergency and I had to push it, I would at least know. I hit 0 to E on my way to the gas station and fueled up with about 35.5 gallons.
2nd time was on accident. I was towing my race truck back from maryland 2 hours away. Watching the Miles to E and knowing how far I had left, I knew it'd be close. Good thing it is still fairly accurate adjusting for towing when the settings are set for it. I hit 0 to E with about 2 miles left to go to my house. I was sweating it because I had a trailer so I figured it would be burning faster than it was accounting for, but I had 5 gal of street fuel in the back so it wouldn't have been a major deal if I ran out. Got home and unloaded the race truck, then I had to go around the block again to turn the trailer around, then back it in next to the house in a tight spot, which took a few minutes, and I had to go 4wd because there was snow/ice in the yard I was slipping in in 2wd trying to back the trailer up. I was almost certain it was going to run out lol. Parked it in the driveway, and next morning went to go get gas about a mile from my house. There's 1 road that is a stop sign on a downward slope. I KNEW if I made it past that I could coast to the gas station the rest of the way if I had to lol. NOPE! What little fuel was left sloshed forward on the downhill braking and it sputtered to it's end. SO close! lol Dumped in the 5 gallons I had and proceeded to the gas station.
Long story short, if I NEED to, I'll run it to 0 to E, but anything past that and I'll be sweating bullets.
99% of the time I fill it up with around 100 to E. As soon as I crack that 100 mark to double digits left, I fill up my next morning on the way to work.
I've always wanted to try it out, but never had a gas can in the back of my truck when I'm that low on gas. I usually fill up between 50-100 miles left. This truck makes it too easy. At 50 miles it starts telling you where the gas stations are, lol.
lol I did notice that, it is pretty funny the nav starts showing you were gas stations are as a reminder when you get that low.
I don't run it that low because I know I'm only getting 100 bucks into the tank before the pump stops.
I guess I could do the math while filling up with a couple ticks left on the mileage meter.
---------- Post added at 10:44 AM ---------- Previous post was at 10:43 AM ----------
Ha, only a truck that gets 13 to the gallon would also tell you where to get more. It's like an addict.
Yeah our limit here is $125. So if I don't fill up before the cluster shows "30 gallons burned" I start getting grouchy, because if gas is around $4 a gallon I know I can get 30 gallons for $120. Usually it's a little less than $4 so I can get 31 maybe 32 for the $125 limit. But I HATE not having a full tank, and I HATE running my card twice, especially since this is NJ and you can't pump yourself so you're waiting for the attendant a second time around, and they won't let you run the same card twice, so I have to use two different CCs. If I max out $125 I always run another card even if it's for $2-$3 worth LOL
The Car Stereo Company
here, on frf
crap, we got $100 limit here. so a full tank from e is out of the question. the lowest i was, it said 4 miles. it was my first tank and i figured the same as you reptar, however there was no gas station 4 miles away, so i had to fill it up.
rwjr
$75 limit here.
My Bronco has a 33-gallon tank and I have to fill up every week (22-26 gallons) because I'll have to pump twice if I wait. At least I'll get better mileage in the Raptor.
f150corey
i run it to a 1/2 tank then fill her up... on the 37 gallon tank it keeps it around 63 bucks... and i do it twice a week. i no i still spend 120$ but i feel better spending 60 at a time.
Wilson
South Dakota
I ran mine to 0 to e and filled it with e-30. gas is the trucks crack it get impatient with you when you let it get low.
Reptar
Jersey
tank is 36 gallons.
I don't know why they set the limits so low. I can walk into any store and buy several THOUSAND dollars worth of anything I want on my credit card without a blink of an eye. But a full tank of gas?!!??! oh no, lets make that a royal PITA, and only let you get 7/8 of a tank, because that extra $10 to fill it ALL the way up is just too risky to grant credit for :Rant:
Wilson
South Dakota
it's not the dollar amount it's the gallon amount for spills. basically dollar but for spills non the less.
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
ps they are a few year behind with the gas price hike
