FSA 21B10 - Cam phaser update?
MtnPat
Just called my local dealer to have the update performed and they claimed it’s not preventative maintenance, they will only reprogram if there is a noise/issue. I’ve never had an issue with the cam phasers (knock on wood). Does this sound right? Or should they reprogram anyway?
K223
Florida
Unless maybe your in a ‘20 it would need to be done. As stated above it’s preventative and puts an extended warranty on phaser repair. It’s even listed as a recall in FordPass and you should have received documentation about it by mail. Maybe your dealer needs to see it in black and white. Have them lookup the recall number or scan and email that letter to them.
DFS
USA
I'm in a '20 and had it done per the recall notice, should be for all of the 3.5 HO Raptor's from what I've read regardless of year.
K223
Florida
According to @FordTechOne the ‘20s did receive the latest revision of the parts used to correct the problem. I can only gather they didn’t get the latest code? Honestly there has been several revisions it seems until they finally manages to correct the problem, regarding parts and the latest code.
DFS
USA
At this point I've stopped trying to understand how ford disseminates this information, I have a late MY2020 build, my VIN was registered for the recall/reprogram, so I did it accordingly. Being issued the recall by letter, by FordPass, and under my VIN at the dealer would contradict FordTechOne's guidance if that's really the case. But I am not interpreting any of this myself, I simply followed the procedures issued to me by the recall.
FordTechOne
Detroit
The new phaser design went into production 11/19, but the new calibration was not available until July 2021. So if late build 2020s are getting the recall notice, it appears they’re applying the update to all vehicles regardless of build date.
isis
PA
Except for @MtnPat ’s degenerate dealership… time to find a competent one. It’s a recall, it’s not preventative maintenance. They did it on mine without even asking. How lazy can a place be?
Ford does do over the air updates, do it on my wife's 21 Explorer and I assume they do them on the Gen 2 Raptors. They have modems and I hear the automation systems run. You can do updates from the main system menu as well with the Wi Fi. In regards to the post, my truck holds the starter a little longer than it did previously to build pressure. I assume this is part of the cam phaser update. However, I did not notice it doing it till a few weeks after I had the hardwired update.
that’s the sync OS, not the PCM, TCM, etc. FTO is saying that the PCM is not updated OTA
Nothing about how the truck is programmed to run, or any settings you can change with FORSCAN are capable of being updated OTA.
jamanrr
It is not there yet but it will be, and I think it hits 21+ vehicles.
I hear the automated systems run and they do over the air updates. The ability to reprogram the main systems will be online soon.
