daveypetey
- Joined
- Aug 3, 2013
- Posts
- 213
- Reaction score
- 23
I didn't see any movement in the lower shock bolt even with it off the ground the 3.0s have less contact area around the lower shock bolt hole on the shock and I can see down into the inside of the aluminum ears on the LCA and I can't see any rub/wear marks or gouging around the spacer. I tried to take a video with my gopro of the LCA bushings and shock mount can't see anything happening with the shock mount probably because of the location of the camera but there is a lot of movement in the LCA bushings. I can't load the video from my phone so I'll have to wait until I get to a computer to load it.
---------- Post added at 09:36 PM ---------- Previous post was at 09:35 PM ----------
I'm running 42 psi in my grabbers what did you lower yours to ?
39 front, 35 rear on my 37" KO2s
