Front end alignment. Issues after springs. Adjusters?
Bryantbjb
Salem Oregon
Hi all, installed Eibach springs. After front end align, truck pulls to left. Done at dealer. Then back to dealer again, still pulls to the left. Went to front end shop, they worked on it for about an hour. Still pulled to the left. Then another tech worked on it. Much better. He recommended putting in “adjusters” or something like that in the lower bolts so when it needs to be adjusted you can do it easier. Tech said the lower bolt is really hard to adjust on the Raptors. Has anyone heard of this?
Peterb
vancouver
the spc product is to help stop the bolts slipping in the adjustment slots and losing correct alignment, should only be a problem if you drive off road or maybe hit potholes hard. if you’re only on pavement the dealer is the problem and you need a good alignment shop, the eibachs may alter the alignment limits and an inexperienced tech may struggle figuring out what to do.
sixshooter_45
Arnold
Ron Lanza
Newnan, GA
I am having my Eibach's installed in the morning. I printed off the alignment spec's for a 2017 SCREW. Any one know if these spec's are also good for my 2020 SCAB.
If not anyone know where I could find the correct spec's
