Front diff cover mod.
niclarsen
SoCal
Did the **** come with the dimple plug as well? Or is that purchased separately?
thisnis exactly what I’ve been meaning to do as well.. does it look like enough of the old guild with come out with that placement of the drain plug?
Thanks for all the info man!!
Finally got time to install the cover. This will make future diff fluid changes easy. This was less than $50 to do w/o the cost of the diff fluid.
REX111
REX111
Sussex
When my truck was at ford and they were trying to figure out the weird popping noise when using 4a. The ford tech said he appreciated the drain plug on the diff cover.
MRV99
HOme
Surprised you didn’t get dinged for “mod in the exact place where the trucks issue is”. I would have thought they would blame you
REX111
REX111
Sussex
i was surprised that the didn't blame me for a modded diff cover.
Moorpark CA
Hey JAndre....were you ever able to get an answer on this question? Also interested if the Spicer 8.8 front diff cover would work on the Gen 2 w/o having to remove the steering rack...
I just installed mine. Yes , the cover clears. Sadly there was no way it went in without pulling down the steering rack.IMG_2694.jpeg
Augster
Sandy Eggo
Yea, I only removed the two large front-facing frame bolts holding the rack to the frame and let the rack just hang down in place. I then jostled it around while slowing lowering and repositioning the front axle on a floor jack inch by inch. I had a helper on the jack following my instructions.
Moorpark CA
Yeah, I gave that a shot for a while without any success. Is yours a gen 1? The oil pan looks different.
