Front camera for ford lock-pick
Dr_Pain
Louisiana
If navtv becomes a supporting vendor i would buy this for my raptor today.
To bad they only seem to be a vendor on that ****** cluster **** of a fagfest forum.
Wooooooooooo.... them be fighting words!! NO NAV-TV for you!:bowroflwerd6:
Steele16
Centralia, WA
How bout adding a front camera tonal '12 without nav and getting the image to appear in the mirror like the rear camera?
TheJoker
N. E. Massachusetts
In this case I believe you could get a video (RCA) switch. Which would be simple and cheap. Contact Chris at Camera Source and get his input. Ford Raptor Front Camera Kit
Something like this maybe?
Thanks J Damage (op), I just ordered the front camera and Lock Pick from Camera Source. The entire kit cost less than the NavTv Allsync.
TheJoker
N. E. Massachusetts
A couple questions for those who have the factory front camera...
Is there a seperate washer fluid resevoir for the camera wash unit?
Could you take a couple of pictures of the supply hose routing? From what I have found, the camera wiring runs to the left side and the washer hose runs down the right side.
The reason I ask, is that I am installing the system in my 2011 using a combination of factory and aftermarket parts. I may install a separate resevoir or tap into the main unit using an aftermarket pump / switch. Still undecided
If I tap into the current resevoir and have to pull the battery to access the it, this portion of the intall may have to wait untill warmer weather. However, I want install the jet and run the hose at the same time I install the camera.
Any advice or input would be welcomed. Most of the parts I need have already been ordered. Thanks.
KeithS
Cabo San Lucas
The hose is routed on the right side of the hood. Looks like it uses the same reservoir. Last picture is looking straight up at the bottom of the reservoir in front of the right front tire. I'm not sure how they handle the valving, but it does spray independently of the windshield.
