Fox Factory Race Series
taquitos
Seattle
A little analysis... I measure the shock travel on stock 35 front shocks at about 7.25". That's 0.4" more than what is listed for these. That would mean they are designed around 37" wheels and will produce about 13" of travel. So, a travel decrease for 35 trucks. It appears for the rear they are matching the shock travel of the 35" shocks. This makes sense because the bump stop is external to the shock so you can just let that limit your travel. No travel changes in the rear.
Some numbers comparing the fronts to the gen 2 shocks. This is a little interesting...
Extended length: gen 3 shocks have a 0.72" longer extended length
Compressed length: gen 3 shocks have a 1.76" longer compressed length
Travel: the shock travel is 1.04" shorter on the gen 3 shocks. (7.89" vs 6.85")
I thought the gen 2 front shocks supposedly decreased travel ever so slightly. If the shock travel is 1.04" longer that would mean they would actually increase wheel travel. But full bottom out with 37s would be even riskier. I can see why Fox would be telling people not to do that. Could making a conversion for the gen 2 shocks so that they had larger studs on the top and longer shock extension on the bottom to match the extended length of the gen 3 shocks be the way?
Daneger
35 Trucks only
“GUARANTEED TO FIT ALL 3RD GENERATION SINGLE VALVE RAPTORS. DOES NOT FIT DUAL VALVE EQUIPPED TRUCKS.”
2slo4u
Utah
Got my FRS 3.2 SV live valve on order for my 23 Raptor R. I’ll have stock take offs available once the race series arrives, no leaks.
Give us a ride report when you get them installed. Would love to hear about it
