Oldfart
Serious question for once! I've done several Forskin mods successfully. In trying to get rid of the startup chimes, I'm stuck. I'm assuming what's called the "Disables three "doo-doo-doo" start-up chimes from cluster" is referring to the chimes that go off when you get in the truck. The sheet calls for IPC 720-01-02 xxxx x2xx
When I reset what starts as 221F 80EB to 221F 82EB and then when I tell it to write and finish, somehow it changes to 221F 82ED. I tried it several different times and the B changes to a D on it's own, and the chimes still go off. When you get done programing it asks you to turn off and turn back on, after I do that it reads a D.
