FORScan on a Gen1
t_j
t_j
Chicago, IL
So you agree, Ford DOES NOT have A-GPS.
As yet that is unknown, especially when fitted with the optional hotspot feature. The GPS is assisted/augmented/enhanced/insert other synonym here with inertial data from the vehicles can network. Now if you want to be a **** about it yeah I called this A-GPS which was the wrong term :sorrysign:
, however the explanation was correct as to how the sync system uses this data even if the name was wrong.
Oh wait you're not not going to admit that you were wrong about sync consuming inertial data from the CAN network are you? :supergay: :shitsweak:
Darick
I was wrong initially, yes. However, I figured I'd take the other "win" that it isn't A-GPS :ROFLJest:
Raptized
Raptorida
So is there a complete listing somewhere so I can sit down and do my 2013 all at one time?
Jhollowell
Everett, wa
Has anyone figured out how to set the drl to parking lights only. I’m looking for the code for a gen 1
Jhollowell
Everett, wa
The info you are looking for is in the thread you posted this in. Just have to read.
I saw that you can turn the turn signal lights on but I’m looking for all the amber lights to be on. Grill and side marker. Basically i want all the lights that are on at night except the headlights as my drl
ogdobber
Not possible via forscan as far as I'm aware on a g1. Turn signals only.
The only way I've seen is a wire jumper near the pass kick panel...
