GEN 1 Forscan Changes you made to your Gen1?
Canuck714
San Antonio TX
Where is the change to 37's?
you have to convert HEX to decimal for each tire brands circumference. I want to say mine was 2888 or 2900 mm
I dont have all the math in front of me but I do remember it was under 726-45-01-xxxx-0000-xx
Once you convert the 2888 mm to the hex code you plug it in the 0000 part... Mine was some goofy numbers and letters combo
oplersx
British Columbia
ForScan is a great tool, have used it on all 3 Raptors for one thing or another. Also a great tool when you are chasing down issues or just want certain things to function a certain way. Im sure there are more things, just dont remember all of them without looking at the laptop I run ForScan on..lol
- Turn indicator 5 flash
- TPMS set to 30psi and then just shut off completely when I went to 6 - 37's
- Tire Size adjusted to 37's
- gear ratio (4:88)
- DRL set to marker lights
- Enable Auto start (2011)
Nice!I will disable DRL (trying to fix Morimoto XB probelm). How do you set turn indicator 5 flash. Forscan module hasn't arrived, trying to make some sense in the head :005:
Canuck714
San Antonio TX
from @BenBB on page 2...
For GEN 1
SCCM
724-01-01 xxxx xYxx xx:
View here: https://forscan.org/forum/viewtopic.php?t=4393
https://docs.google.com/spreadsheet...J8uUqpLwP_xyqbfQHB0rAnXNs/edit#gid=1741285730
0 = 1 flash & OUC False
1 = 1 flash & OUC True
2 = 1 flash & OUC False
3 = 1 flash & OUC True
4 = 2 flash & OUC False
5 = 2 flash & OUC True
6 = 3 flash & OUC False
7 = 3 flash & OUC True
8 = 4 flash & OUC False
9 = 4 flash & OUC True
A = 5 flash & OUC False
B = 5 flash & OUC True
C = 6 flash & OUC False
D = 6 flash & OUC True
E = 7 flash & OUC False
F = 7 flash & OUC True
So set 6th digit to b gives you 5 flashes in the same configuration as stock. Will give you 7 with a trailer.
oplersx
British Columbia
For GEN 1
SCCM
Thanks! Starting to make sense :D
oplersx
British Columbia
Half success! Looks like I fixed Morimoto XB headlights issue by disable both DRL and DRL with turn lamp (something like this, forgot exact words).
But I can NOT make change in this format : 724-01-01 xxxx xYxx xx in SCCM. I can delete a digit but it doesn't let me input anything.
SVTRap
Big Sky Country
Do you have a standard or extended Forscan license?
oplersx
British Columbia
Two month trial license, pretty sure it's extended. Probably my adapter? When I start forscan the first time, it says adapter is not fully compatible. I returned and ordered another one.
ExcessPlay
Atlanta GA
Just a note to other new Gen 1 and new Forscan users. I was attempting to modify my side folding mirrors to fold on lock and unfold on unlock, Lincoln style, however I learned after much searching, of course after I had already purchased the Forscan module and downloaded the software, this function did not become available until 2015. There is no DDM, Driver Door Module, or PDM Passenger Door Module on the Gen 1, 2012-2014 F-150.
MEIRONMAN207
¿Goin somewhere...What are RU waiting 4?
Maine
I have a 2014 and can close the mirrors, not automatically but with a momentary push towards the rear on the adjustment toggle...dont need a program was standard
ExcessPlay
Atlanta GA
Yes mine close that way as well. With Forscan in 2015 you can program when you lock with your remote the mirrors automatically fold in, when you unlock with the remote you have two options either fold out immediately or you can program them to remain folded in until you open and close the door then they automatically fold out.
Not a big deal, just a convenience thing and my wife would no longer have to squeeze by my Gen 1 when i forget to fold them in...
