GEN 1 Forscan Changes you made to your Gen1?
letsgetthisdone
Las Vegas, NV
The turn signal flash mod sounds awesome. I'm doing that this weekend, the 3 flash is silly. Not enough for a lane change unless you're yanking the wheel over lol.
Has anyone confirmed where we can set TPMS alert pressure? I'd like to move that down to 15psi or 20psi so I can actually use it as a flat indicator offroad when i set my pressures to 25psi or so.
IDI-Charlie
Staunton, VA
I could see that with a factory scan tool. Hopeing its different when we actually have access to the code, vs an interface chaging the code for us based on the number we punch in.
Checked the forscan spreadsheet I have on my phone, all I had was a setting for high and low range. Will have to dig up the master on my computer to see if it has any more info.
I know the Super Duties can be set to the desired pressure via hex, but I'd have to do some digging to verify compatibility with the Raptor.
letsgetthisdone
Las Vegas, NV
Appreciate it man. Lmk if you can figure it out.
oplersx
British Columbia
Its a fantastic resource....
So a few things I have done to my truck with Forscan:
  • Turned Off DRLs for the LED Headlights
  • Disabled HyperFlash for the LED turn signal bulbs
  • Programmed a Sync 3 APIM module from an Explorer so it would work with my truck and added the prerequisite Ford Performance Raptor load screen
  • Chase down DTCs and reset
Im sure Im forgetting a few but I'll also be using it to turn on ambient lighting once I get to that point and Im still using it to try and chase down an issue with my upgrade to Sync V3.4
For LED headlights, did you just disabled DRL? Forscan OBDII adapter is still on the way so I have no idea what it looks like on computer. I looked at a spreadsheet online, it has 4 options?
726-11-010001000040DRL Disabled
726-11-010101000041DRL Enabled, Low Beam
726-11-010201000042DRL Enabled, Fog Lights
726-11-010301000043DRL Enabled, Turn Signals
SVTRap
Big Sky Country
Correct and on this one you can toggle the setting without having to get into adjusting the address value as you have shown above (once you have the program up and running it will make a little more sense).
Canuck714
San Antonio TX
ForScan is a great tool, have used it on all 3 Raptors for one thing or another. Also a great tool when you are chasing down issues or just want certain things to function a certain way. Im sure there are more things, just dont remember all of them without looking at the laptop I run ForScan on..lol
- Turn indicator 5 flash
- TPMS set to 30psi and then just shut off completely when I went to 6 - 37's
- Tire Size adjusted to 37's
- gear ratio (4:88)
- DRL set to marker lights
- Enable Auto start (2011)
