GEN 1 Forscan Changes you made to your Gen1?
SVTRap
Big Sky Country
I believe some of the earlier trucks still used the 90s era fob that was separate from the key so there would be no provision for a start button
The Car Stereo Company
here, on frf
2010s. 2011 and up had the remote start option when you got the 801a package. 2013-14 are slight different but incorporate the same remote start.
True true, but did they have the buttons on the keys? I love remote start, even though I live in Norcal I like starting the truck in the morning so its ready to go.
if there was no remote start, the key will have a blank spot where the 4th button is
JefeAZ
Tucson
You can adjust the tire pressure to whatever # you want? Or 0-15 so it basically only comes on when you truly have a flat?
What is hyperflash? Where is 3 to 5 click on the turn signal and NAV lockout? Dont see those in the spreadsheet
Can you activate the front cam above 15mph?
JefeAZ
Tucson
Hyperflash is when running aftermarket turn signals?
What else is everyone else changing?
here, on frf
its when led turn signals are added. leds take less current and therefore has less draw. the flasher is based of resistance so if the resistance isnt there, it will flash fast.
and as far as i have seen, you cant program the front cam
vanndamage
I used Forscan to fix hyper flash on my 2011 when i replaced all the tail lights with LEDs. Also used it to help my buddy with a regular F150 who upgraded his tire size to fix his speedometer with right hex code for his tire size.
B E N
Frederick, CO
@JefeAZ
For GEN 1
SCCM
724-01-01 xxxx xYxx xx:
View here: https://forscan.org/forum/viewtopic.php?t=4393
https://docs.google.com/spreadsheet...J8uUqpLwP_xyqbfQHB0rAnXNs/edit#gid=1741285730
0 = 1 flash & OUC False
1 = 1 flash & OUC True
2 = 1 flash & OUC False
3 = 1 flash & OUC True
4 = 2 flash & OUC False
5 = 2 flash & OUC True
6 = 3 flash & OUC False
7 = 3 flash & OUC True
8 = 4 flash & OUC False
9 = 4 flash & OUC True
A = 5 flash & OUC False
B = 5 flash & OUC True
C = 6 flash & OUC False
D = 6 flash & OUC True
E = 7 flash & OUC False
F = 7 flash & OUC True
So set 6th digit to b gives you 5 flashes in the same configuration as stock. Will give you 7 with a trailer.
That spreadsheet has the info on tire size and NAV in it as well.
For Gen 2
SCCM
0 = Triple flash disabled
4 = Two flashes
6 = Default Triple flash operation
7 = Turn signal stays on until canceled
8 = Four flashes
A = Five flashes
C = Six flashes
E = Seven flashes
Source and video https://www.f150forum.com/f118/another-great-find-forscan-users-turn-signals-388201/
