Livin;
Was responding to another thread on the gear shift indicator and wanted to ask you if you have seen in IDS the option for locking the gear shift indicator display to "on" all the time.
If so, I wanted to do this with FORSCAN since it's annoying to look down and see an all blank display section on the right side of the tach and realize that once again you've accidentally hit the +/- buttons on the gear shift lever.
As I mentioned in the other thread on that topic my 2011 XLT had to go in to the dealer for some sort of programming and when it came back the gear display was permanently on and hitting +/- had no effect on making it go away. This is my desired end state goal.
So if you know how the dealer would have done that with IDS please let me know.
Thanks,
S.
---------- Post added at 11:53 AM ---------- Previous post was at 11:38 AM ----------
I tried a few more changes from the database and forum info. Ive been able to get several features to work such as DRL to cluster control, double honk disable, autofold mirros lincoln style, HSW and heated/cooling seat icons in climate menu, engine and transmission temps above cluster and TPMS specified value displayed. My vehicle is a 2018 Raptor and it has Sync3 V2.3. Here some questions additional questions i have. Thanks everyone for all the help and excellent information here.
2. Reverse tilt mirrors doesnt seem to work. Ill have to double check if my mirrors have memory, but my seats do, so i figure the mirror memory should be tied into that as well.
3. Can someone explain to me what the battery monitoring system is? When i have it set to enabled, it seems to prevent auto start/stop from working. Im getting a message in the menus saying that the battery is recharging or something along those lines. Perhaps it could be another way to disable auto start/stop.
4. I guess bambi mode is not necessary for raptors since we dont seem to have foglights?
Re; 2. After setting the values for tilt mirrors there is a procedure to be followed for each mirror, involving putting the gear selector in reverse, pressing the left or right mirror selector button and then adjusting it to what you expect to see (tilt down a bit) and then pressing the memory 1 (or 2) for 5 secs, and then doing the other mirror the same way. NOTE that even having done this the mirrors will only tilt down when you are in reverse and *select that mirror* button (you can't select both at the same time as you know).
Re: 3. Battery monitoring system ensures that essentially you don't run down the battery and that it is charged properly. Having said that if you want to disable stop/start there are very specific settings in the spreadsheet that also will remove any other indications/warnings you would get by doing that. Like the battery monitoring system one you refer to here.
Re; 4. Correct. And since we don't even have the headlight switch that has the fog light button it's just easier to add lights and use the upfitter switches instead. Unless of course you wanted to get a switch and harnesses and configure it all to work like a regular 502A (or higher) trim level F-150. I guess that's possible with FORSCAN and the correct harnesses and some lights of your choosing.
S.
