blwn
Florida
Awesome, that worked great!
Do you know if there is a way to also update shutdown logo to Raptor rather than Lincoln?
I don't believe so.. you will also see Lincoln Connect or similar instead of FordPass in the settings. It's just part of using that theme. The startup logo should stay as Raptor though
ljn21
Tega Cay, SC
GCATX
King Dingaling
Central Texas
I am no Forscan expert so please do your own dillegence but I believe the BFG KO2 tires in stoc 315/70/17 size is
BCM 726-12-01 xxxx 0A68 xxxx
I found that here: https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview# under Tire Size Value Tab/Menu.
Sorry, I probably wasn't clear. I am running the stock tires but the speedo is off. I need the digits for a tire that is smaller so the speedo will read correctly. Just wondering if anyone has tackled this, I do run around 35 psi frt, 32 rr.
ljn21
Tega Cay, SC
Got it, sorry, yes misunderstood! You could check the link I posted above, it lists some other sizes, not sure if anyone of them would get you close though or not. You would have to figure out what % off your speedo currently is, then do the math the new size/current size tires to come up with a size that gives you the same % dif.
Todd Turbo S
Nor Cal
Well, I didn’t get too far. First thing I’m doing, is trying to back up all my Factory settings. I followed the
Tutorial here https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
And when I hit the connection icon on the lower left, it starts by trying to locate a WiFi single when I have a hard connection. Anyone can assist with trying to get Forscan to use my hard connection? I figured it would read automatically.
Steve_S
USA
I used that connector as well and it was fantastic. It has an auto selector instead of a switch and transfers data at a faster level. All around problem free unit.
Make sure connections are seated in both ports.
When you received it and plugged it into your laptop was the connection light yellow? If it was yellow it means drivers were up to date. If it was not yellow drivers need to be updated.
Todd Turbo S
Nor Cal
Thank you for the response. No yellow light, the light was red. What drivers are you referring to that needs to be updated? Drivers on computer? I’m not very tech savvy and the connector is brand new. More feedback would be appreciated.
Thanks.
Steve_S
USA
Thanks.
Grab the package the module came in. There are direction written on it that say what to do if it’s plugged into a computer and is not yellow, you then need to go to a site and do an update. It’s on the package. I will see if i can find mine.
