dboat
Dallas, TX
Hey guys,
Took my first shot at forscan and did:
-Auto start/stop button disable
-Lincoln folding mirrors
-Engine temp # displayed on gauge screen
-Heated steering wheel + heated/cooled seats on homescreen
-Disable double honk
All the changes work great but I noticed when scrolling through my configured screens that my tire pressures are no longer reading. Has anyone experienced this? Hoping it's an easy fix instead of reverting every module back to stock. Thanks in advance!
This is what I want to get done. Where can I get this done in Dallas?
Will it impact my warranty?
Dana
Sent from my LM-G820 using Tapatalk
CHMP
Santa Cruz
Dana
Check out the document on post #1 on this thread. That's how I got it all done, took me about an hour of careful reading and a $40 Forscan adapter on Amazon.
dreys
San Diego, CA
Has anyone been able to successfully (and persistent) update the theme on 19-20 Sync 3.4? I can temporary change theme through Test Settings menu, but that doesn't stick after restart.
I have also tried APIM settings (7D0-03-01), however unfortunately that didn't work either.
Is there a different way to update the theme?
blwn
Florida
Which theme are you trying to use?
GCATX
King Dingaling
Central Texas
Anyone have settings to correct the speedo with stock tires? I seem to be reading about 2-3 mph high than GPS, I guess from running lower psi.
CHMP
Santa Cruz
Hey all, anyone know if it is possible to permanently turn off the rear parking assist alarm? I have a hitch-mounted bike rack I would love to leave on the truck, but everyone I reverse I have to manually turn off the park assist alarm. Mild inconvenience to be sure, but cool if I could Forscan it out.
blwn
Florida
This should disable it permanently:
IPC 720-02-02 1xxx xxxx - Rear Park Aid Control disabled
PAM 736-03-01 x7xx xxxx xx - Rear Park Aid disabled
dreys
San Diego, CA
That was my guess.. For the Lincoln theme you also need to set 7D0-01-02:
Change the first 0 to 8 (8xxx xxxx xxxx)
Awesome, that worked great!
Do you know if there is a way to also update shutdown logo to Raptor rather than Lincoln?
