MJK
I have Forscan setup on a 2013 MBP with Catalina using VirtualBox and one of these free VMs from MS: https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/ OBD2 device has to be assigned to pass-through to VM, but it seems to work.
So far it works, but I've only read from the truck. Have NOT written anything yet, still trying to make sure I'm 100% certain how the UI of Forscan works.
Assuming it actually works writing to it, this is a 100% free solution for MacOS, no Windows license required. The Windows VM only last 90 days before you have to download another, so be sure to copy any backups to host machine's hard drive.
Update?
Livnitup
SoCal
Hey guys I didn't see on the spreadsheet where you can adjust for different tire size (37")
Can someone point in the right direction ?
Thanks
Tire size is set in the BCM module. Use the link on row 61 of my BCM spreadsheet here to calculate the correct value to use for your 37's: https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=0
After you change the tire size you'll likely get the wrench on the cluster so then you need to run the PCM Relearn procedure (first item in the programming icon screen of FORScan) and if a TCM relearn procedure is listed for you in the programming screen then run that also to remove the wrench.
Donmatteo
Santa Clarita / Coronado
Thanks for the clarification Livitup
REMIX
Sarasota & Jacksonville, FL
OK so I disabled the start/stop and added the temp to the gauges. Disabled the horn honk annoyance but then noticed my console light stays on constantly. Unsure if that was related so I reversed the change. It's still on and I started a thread about that.
https://www.fordraptorforum.com/threads/whats-up-with-this-led.73257/
I̶'̶m̶ ̶a̶ ̶l̶i̶t̶t̶l̶e̶ ̶t̶e̶r̶r̶i̶f̶i̶e̶d̶ ̶t̶o̶ ̶d̶o̶ ̶a̶n̶y̶t̶h̶i̶n̶g̶ ̶e̶l̶s̶e̶ ̶n̶o̶w̶ ̶L̶O̶L̶,̶ ̶e̶s̶p̶e̶c̶i̶a̶l̶l̶y̶ ̶w̶h̶e̶n̶ ̶i̶t̶ ̶s̶a̶y̶s̶ ̶i̶t̶ ̶h̶a̶s̶ ̶c̶h̶e̶c̶k̶s̶u̶m̶ ̶e̶r̶r̶o̶r̶s̶ ̶a̶n̶d̶ ̶i̶s̶ ̶g̶o̶i̶n̶g̶ ̶t̶o̶ ̶"̶r̶e̶w̶r̶i̶t̶e̶ ̶t̶h̶e̶ ̶e̶n̶t̶i̶r̶e̶ ̶m̶o̶d̶u̶l̶e̶"̶.̶
EDIT: OK nevermind, I waded in a little more once I figured out how to save the modules. Now got the heated/cooled icons on the home screen (why was this even left off?) and disabled the honk.
No auto shut down at stoplights anymore!
This is addictive.
bigskyRaptor
MT
Went to enable secure idle in BCM module today for my 19. It was already coded for this option. Is this standard for all Raptors?
