SCMike
San Clemente
That's what held me up from messing with the Auto Start/Stop in Forscan. Just unplug the bottom two wire plug from the white module just under the drivers side dash, on the left hand side.
Here is a YT link: Start at the 1:00 minute mark.
this is super simple, but I would likely forget to plug it in when towing. I’ll try the forescan mod and see if that works. Thx for the response.
K223
Florida
That option doesn’t exist with FORScan. NAV-TV sells an adapter for about 400 bucks that allows this.
Can dig up the part # if you want to go that route. I’m not sure if I would use it enough to spend the money on it.
WRCRaptor
Great Lakes
Thanks, I would only want it if it can be turned on via Forscan. I am aware but have heard mixed reviews over the years about it.
K223
Florida
Interestingly enough there is a simple mod to remove a wire that allows you to light up the rear spots on the side mirrors at any speed.
I would have to think there could possibly be a simple mod to do the same for the cameras. Maybe not or who wants to be a guinea pig and screw this up by trying.
Maybe some day.
waveslayer
CA
I have looked around and can't find if you can use Forscan to allow front and rear cameras to be used at any speed?
I installed the Naviks system on my truck. Allows the cameras to work any speed. I don't use it a lot, but I do when towing or off roading.
I also got the phone mirror option, that I use all the time.
Here's when I towed my buddy who ran out of gas.2f833273b82cfa66ec37782e5faddcf8.jpgf86efed9a608938aa2f4b412f4ea39cb.jpg
My wife thinks I only have 3 guns
RexDad
Dallas, TX
What does the Phone mirror option do?
Livnitup
SoCal
FYI: I've changed my recommended adapter on my tutorial for anyone getting started with FORScan to the OBDLink EX USB adapter here for $40: https://www.amazon.com/dp/B081VQVD3F
This adapter has a built-in switch, is capable of firmware flashing, and 9x faster than a regular USB Adapter like the OHP/VINT with toggle switch. I just had a conversation with the FORScan developer about it and this is the real deal and almost as fast as a J2534 adapter so it's a lot of bang for the buck and there is collaboration with OBDLink & FORScan on maximum compatibility. I've been testing this adapter out for the last few weeks and it doesn't disappoint!
