tommys1081
NJ
I'm in NJ - downloaded Forscan, bought the recommended module from Amazon, followed all instructions to a tee - and can’t get it to connect. So frustrated.
southof30A
Denver
Looking for someone in the north Denver area that could make some Forscan changes on my 2018 Raptor. I'm not confident in my ability to not mess things up.
Happy to compensate for your time.
cwylie
Anyone had their miles till empty go kinda wacky after a few changes? Im getting 15ish and its saying I have 600 miles to empty which I have never seen before.
cayenne
Windsor, CO
I'm in NoCo and would be happy to help out if you can't find someone closer.
rtmozingo
North Texas
BCM
726-40-01 xxxx **xx xxxx TPMS Placard Front Tire Pressure (convert p.s.i. to hex)
726-40-01 xxxx xx** xxxx TPMS Placard Rear Tire Pressure (convert p.s.i. to hex)
Examples:
726-40-01 xxxx 1E1E xxxx - 30 psi front & back
726-40-01 xxxx 2323 xxxx - 35 psi front & back
Just to confirm, if I wanted a setpoint of 34 front and 30 rear, I'd go to BCM 726-40-01 and change the middle column to 221E, correct? Thanks as always. Just bought the phone app, looking forward to trying it out.
Killingtommygun
Plainview, MN
The first page on the link tells you how to back up the values that are there already (definitely recommend doing this) then there is a link to a Google DOC that tells you what values to change for what feature. Start with the "common" tab. It should have everything you're looking for. You need to register on the FORSCAN site so you can get the extended license. Follow the detailed steps in the first post on the link and you should be fine.
Im going to drive down from Minnesota to you when i get my Raptor and pay you lol. No idea how to do this shit
